pabloweb
3 November 2014
civil-zz:
pabloweb do you have a link to such booklet? i think it is a ford or publishing fault.. it's a funnily of course if it so  |
hi civil,
below the image of my C-MAX booklet, it's in Italian language but I translate in English:
hold "set" to set the tire pressure. calibrates the system to the actual pressure of the tires
and below the image of my dash after check the box EPB (level 1) / DDS (level 2/3) in ELMConfig (HEC Map)
civil-zz:
Tonight I will do a scan of the page in question and I will send you the pdf. Thanks
pabloweb
3 November 2014
civil-zz:
it's a request to Ford. DDS can't be activated on C-Max except only case if set the Focus vehicle type in PCM VID-block and perform BCM initialization. |
Thanks Civil-zz for you answer, the strange thing is that the DDS funtions on C-max service booklet is mentioned (chapter setting controls display - SET --> pressure) bat on my version (C-MAX plus version year 2009) this funtions is not present. why?
Thanks
P.S. what are the risks to set "Focus" vehicle type in PCM VID-Block ? i have to load new firmware ?
pabloweb
3 November 2014
Please add DDS funtions on Elmconfig for C-MAX I (year 2007-2010)...
Thanks!!!
