tracer
PL (PL)
tracer
16 April 2018
sam275
Here is the list of changed files: AL vs AM
tracer
6 January 2018
Yes, I am a4tech. I am talking about F7 maps combinations.
tracer
6 January 2018
KuZia495
1U5T-14G421-BAC does NOT work with old builds: 1U5T-14G421-BCA and 1U5T-14G421-BGA.
To get it working it needs: 1U5T-14G421-BAA.
Guess We need wait for new build.
tracer
6 January 2018
Just think that Ford will change links and servers at all if all goes those way.
tracer
6 January 2018
I think it is time to stop public links to the ISVU.
https://www.mustang6g.com/forums/showthread.php?t=84987
tracer
4 January 2018
Flashed in 2015 Module along with new F7 Maps
tracer
26 June 2017
arcomp
I have exact same problem. I think it metter of PCM calibration.
tracer
17 March 2017
gonghao
No changes. I have no idea why it does not work but my suspection is only PCM.
Regards
tracer
7 March 2017
gonghao
Thanks I have connect it same way but it does not work.
tracer
6 March 2017
gonghao
by the way,
Boost / Oil Temperature / Oil Presure ( from ST or RS ) works fine on 1.5 EB and 1.6 EB ( KUGA ) but it does not work on FF MK3 1.6 EB do You have an idea why ?
How can I check problem ?
Do You have communication diagram or some tip how to check it ?
tracer
5 March 2017
gonghao
So we need to check diffrent SASM.
My expirience:
I have installed FL SASM on:
1.6 EB with manual transmission with normal Cruise Control with ASL - LIM button is not working.
1.6 EB with manual transmission with ACC -> RES+ and LIM button is not working
In both cases LIM button is not working. SASM is diffrent on both cars - One is Full with Heating line assist, other one is simple one along only with Cruise control ( manetes are diffrent as well )
tracer
5 March 2017
gonghao
I checked MY2015 Car and it has:
CCM: F1FT-9G768-AD F1FT-14D049-AC
SASM: F1FT-3F818-BC F1FT-14C309-AC
IPC F1ET-10849-BLH F1ET-14C026-ABH
BCM: F1DT-14A073-EF F1DT-14C094-AF
The same which I ve got.
tracer
4 March 2017
gonghao
No idea then what cause it. My idea is only PCM calibration.
tracer
4 March 2017
gonghao
So We need to check Resistance after button press but I still do NOT understand... We have all new modules in cars and even that it does not work.
I checked Direct Config for CCM and other things from FaceLift 2015 VIN car and there is no diffrence.
tracer
4 March 2017
arkanoid
Yes I had an orginal one with mods I have done. Perhaps that is some tip... I will give a try perhaps tomorrow.
tracer
4 March 2017
gonghao
I guess We need to compare resistance for FL and preLift buttons manete.
tracer
4 March 2017
gonghao
My Car is 1.6 EcoBoost with Manual Transmission as well.
tracer
4 March 2017
gonghao
Before I had new SASM + Face Lift steering wheel with NORMAL Cruise Control and LIM and SET+ was not working as well.
tracer
4 March 2017
gonghao
I have BCM from Face Lift as well but it does not help.
Did you compare LIN Pin in C346 and C346MCA - is there any diffrence ?
tracer
4 March 2017
arkanoid
Yes sure.
Here is my list:
