pawelekm
22 September 2014
Hi m_stavros,
My throttle body looks quite different (engine 1.8l petrol).
Can i replace the throttle position sensor ? The problem is - i never seen this sensor separately for purchase (only together with throttle).
Maybe there are some replacements ?
Another thing: i was told that i had damaged dashboard (electrical path on PCB) ...
So either throttle position sensor or dashoboard ...
pawelekm
18 September 2014
Hi. Please help. I have C-MAX 1.8, petrol, 2003 year. Lately, a car still give me these two errors:
- P2122 - Throttle/Pedal Position Sensor/Switch D Circuit Low
and
- U1900 - CAN Communication Bus Fault
Engine light if OFF, but the dashboard behaves strangely. It hangs up.
Here it is - before start engine and when i start engine: "http://youtu.be/ZGA5vyBcVdg"
Dashboard displays messages:
- engine fault
- reduced acceleration
I can't delete these errors with ElmConfig, these will return again in a short time.
Despite this, the car drives normally ...
I wanted to find solution on this forum but i hardly speak Russian (even with google translator it's difficult).
I asked on other forums in my country but i didn't get a reply.
Should i replace a gas pedal ? New or used ? (used is much cheaper than new one ...) Fuses ?
Please give me an advice.
