civil-zz
Thanks for the update! Cruise control activated and tested without any issue. Keep up the good work!
civil-zz:
your PCM is Bosch EDC16C34 ECOII thank you a lot, it's my failure related specifically to this module type, i'll fix it in next program version |
Ok, but I tried EDC16C34 ECOII in ELMConfig with the same result, or is that the failure you mentioned about?
Mine is a 115gr/km CO2 version.
Looking forward for the next version, thanks!
Sorry, civil-zz, found out the link is not visible 1 minute before your post.
See link:
It seems my link is not visible in my post. See link below.
civil-zz
I've tried to enable cruise control on my 2010 FF2 1.6 TDCI (109/110; Partnumber: 9M51-12A650-BG), but ELMConfig 0.2.11c complains the selected PCM does not match the PCM in my car. I've tried both Bosch EDC16C34 and Bosch EDC16C34 ECOII using the following procedure:
1) Read from PCM
2) Save to file
3) Enable "integrate speed control"
4) Save to (another) file
5) Write to PCM
I've upload my log to
In this log you'll find the following:
1) Read PCM Information
2) Read PCM Configuration
3) Write PCM Configuration
Do you have any idea what is going wrong? Is my PCM not supported by ELMConfig yet?
