metel
Offline and Online Elmconfig Show's that my KVM is from KUGA.
I tryied to change the settings. but it failed
erniio
17 March 2014
Hello Cywilno-ZZ.
I'v got question , why ELMConfig show's that my KVM is from KUGA?
I have FF-2
ZaQik:
erniio 1. old IPC is in car 2. in IDS: install new programmable modul 3. IDS says "replace IPC" 4. IDS configures new IPC |
So i did it last time , and the IDS says "NO" invalid part number or something like this
So i need to programm old IPC then, i put new IPC and car should run
erniio
17 November 2013
ZaQik:
erniio
on HEC-Configuration-Page_1 is select-menu about ENGINE ... what is selected? ENGINE DV/DW (1.6 TDCi) or ENGINE LYNX (1.8 TDCi)? |
Lynx 1.8tdci
I added the keys into IPC . but not ipc to pcm
How it's possible to programm IPC (from 1.6 tdci to 1.8 tdci) with PCM(SID202)
I'v got orginal IDS Please that's very important for me
ZaQik
I did like you say, i noticed DTC: B101E IMMO, doesnt match in pcm or something like this
When i try to "Add" IPC to PCM the ids says "incorrect part number "
ZaQik:
if you set OLD KVM SYSTEM in IPC, you do not need keys programmed (keys are saved in PCM and KVM, not in IPC)
if you cannot start your car, what error is on display? or DTC from KVM and IPC? |
I tryed like that but the car dont want to start: I was in service . IPC are from 1.6 tdci to 1.8 tdci
The IDSsaid that it's impossible to "Add" IPC to Vehicle .Wrong code finis or like that im not sure.
The Car also dont want to add keyfree to start the auto
Sorry for new post,i need help by programming keyless system :
I configured my IPC by elmconfig. IPC are from 1.6 TDCI .but i changed inelmconfig to 1.8 tdci
IDS/WDS dont let to programm new key or RKE transmiter.
Please give me tips how to programm
It is possible to get RKE ID , or only programming with FORD IDS?
On the old config IPC , the engine doesn't start , but when i use your picture that work for few seconds . The Ingnition allow to run the engine but my battery was under 11 V. So ill try to download old As-Built and try
vitasku
The second test go wrong , car dont want to run , IPC DTC :ID KEY , and PCM DTC: ID KEY
Ok i was in garage and i set config just like you and the engine want to start but my battery was under 11 voltage . ill try in next 2 hours
erniio
9 November 2013
Ill go check give me 10 minutes
I did it like in your photo, the "ignition is unlocking by pressing clutch. But the engine doesn't want to start
I have a keyless car, with new IPC restayl. So when i go to service what should they do . Few people in poland can pair restayl IPC
ZaQik
Focus II 1.8 TDCI
IPC is now Restayl
How i can get ID RKE
erniio
8 November 2013
It doesn't work , i've noticed that the RKE is Incompatibility with transmitter security immo
DTC : B101E
What should i do how to solve this problem
erniio
5 November 2013
Thank you VITASKU and SYSTEMROOT for informations
