civil-zz
sorry, I can't understand your explanation.
pls give me more information, thank u.
ittrium:
ago Raed DTC first. Maybe you are trying to flash wrong firmware. |
can we use elmconfig to downgrade or upgrade PCM version ?
also , what's the DTC ?
thank you .
ittrium:
ago
Read DTC first.
Has flashing finished successfully? |
successed , but engine fault.
ago
28 October 2013
Sholoikocivil-zzafter flashed PCM , restart car ,
a error is coming up.
what's wrong with it ?
SholoikoSholoiko:
Gloom_NK сейчас нет программы под рукой, для уточнения: выбрали прошивку с vid, программа спрашивает да нет , да - грузится из прошивки, нет - программа открывает конфигурацию (на случай если мы хотим что то подправить) и только потом начинается перепрошивка? |
So We understand this Dialog information :
select YES : the software will falsh PCM with original *.PHF file format.
this Status is Standard factory settings.
select NO: the software will falsh PCM with opening the configuration .
this Status is modified settings .
Is't right ?
ago
28 October 2013
civil-zzSholoikoI am flashing the PCM .
PCM TYPE : ESU418
firmwware number : 8M51APP
windows sysytem : windows7 32bit
ELM ship : silicon Laboratories
Silicon Labs CP210x USB to UART Bridge (COM3)
ues the ELMNCONFIG 0.2.11C
procedures--page2--
I check the "read firmware from PCM to BIN-file" button.
a error disply showed :
Incorrect response from ELM to request
"10 85";
7F 10 22
22-Conditions not correct or Request sequence error
can help me deal with it ?
thank you .
Sholoiko
civil-zz
PCM TYPE : ESU418
procedures--page2--
"10 85";
7F 10 22
thank you .
Sholoiko
civil-zz
In fact,we use Elmconfig0.2.11c to downgrade PCM Version ,but not upgrade it .
Is it OK ?
civil-zzcivil-zz:
ago unfortunately I don't understand neither Chinese nor Google-translate from Chinese to Russian or English. if you or someone else clearly describe the issue here in English or Russian (most preferably) then probably somebody here could help you |
so sorry, I can't understand russian .
how to post a topic at forum ?
Or, can I email to you ?
thanks!
Sholoiko
thank you very much .
we'll try it.
civil-zz:
ago Different from what? ELM327 is able to flash PCM if it follows the original specification and can support necessary data exchange speed |
for the different ELM327 chip .
somebody said to me ELMCONFIG didn't support some ELM CHIP.
I have not a VCM box .
In china ,somebody test the elmconfig0.2.9 to flash PCM,
successed ,but Engine error.
you can check the web ,see the photoes.
h++p://www.xcar.com.cn/bbs/viewthread.php?tid=18990263
what's wrong ?
Hope you to help us,thank you.
civil-zz
by the different ELM327 cable , did the elmconfig0.2.11c support to falsh PCM (ESU 411/418) ?
ago
26 October 2013
Sholoiko
In china ,somebody test the elmconfig0.2.9 to flash the PCM,
successed ,but system is wrong.
you can check the web .
what's wrong ?
ago
26 October 2013
Sholoiko:
Romich811 в новом версии возможно будет англоязычная версия) |
so sorry , elmconfig have not a Tutorials for falshing PCM by ELM327 cable.
good morning .
did anybody teach me to flash PCM by elmconfig0.2.11c
ESU-411/418
1.8AT
thank you first.
