Ferolo22
PL (PL)
Ferolo22
28 October 2013
civil-zz
mlk:
I'm not an expert, but: ELMConfig reads/writes not all firmware to Bosch PCM, but only vid+calibration, but not strategy - maybe firmware without DPF that Ferolo was trying to load was full: vid+calibration+strategy - could it case problems?
What is in calibration and wht is in strategy?
what do you think about the post above?
1. how did you download that firmware in your car? did you do this in car or did you put out the on-board computer and download the firmware at home?
2. can you connect directly by elm 327 with the engine driver that is put out of the car? if it is possible then how?
Ferolo22
27 October 2013
I check everyfings what do you tell me and everyfing is ok
Ferolo22
27 October 2013
I try again write this soft 7M51-12A650-UG.PHF and when is 100% I have this frame
Incorrect response from elm request
"37"
7F3772
72- Transfer aborted
Fuck I fire this car
Ferolo22
27 October 2013
when i try write this pcm soft 7M51-12A650-UG for my car i saved this log this is not all?
http://www39.zippyshare.com/v/60334503/file.html
Ferolo22
27 October 2013
civil-zz
how should I do it?
Ferolo22
27 October 2013
Yes I know, the last link is my old firmware witch I had before I damage my car...
Ferolo22
27 October 2013
And this is my old file
http://www9.zippyshare.com/v/81795013/file.html
Ferolo22
27 October 2013
Please try download file from this page
http://www73.zippyshare.com/v/49252915/file.html
Ferolo22
27 October 2013
I try wrote file in 500000 speed I use elm 327 v1.5 and the size block is 256 but I try 64block and 128 and I always have the same problem.
I try write original file, next I try writ my old file but any time when is 100% the frame with such an information shows
"37"
7F3772
First When I download my old soft with pcm file I must chose 103 block because only this way I can load files
Ferolo22
27 October 2013
14:59:48.764 > ELM327 v1.5
Ferolo22
27 October 2013
ddfsdf
Ferolo22
27 October 2013
kdfd
Ferolo22
27 October 2013
civil-zz
Hi i try again write file to my pcm and i have the same problem when is 100 %
"37"
7F3772
Ferolo22
27 October 2013
civil-zz
This is my vin
WF0WXXGCDW7D15585
Ferolo22
26 October 2013
My elm communicates with the car with the speed of 50 000 and there was no problem with the pcm ripping, choosing 103 blk
Ferolo22
26 October 2013
I did the backup for pc and tried reupload it but there was this error at the end
"37"
7F3772
Ferolo22
26 October 2013
I tried to upload original sofware from the web with softwares for ford ( Sergey's table)but it didn't work anyway...
Ferolo22
26 October 2013
what is that stock fw? I tried to upload the software for pcm but at the end of instalation there is an error:
"37"
7F3772
Ferolo22
26 October 2013
If someone didn't understand me, I mean, do you know when elm will be able to upload software for pcm for ford focus 1,6 tdci, because at the moment there is no such possibility
Ferolo22
26 October 2013
civil-zz
Hi! So will you help me with my car problem??
