Good morning, I have a problem with the Radio sony 6000cd.
For a few days I do not recognize the bluetooth module, and when I recognize it in playing songs via usb and cellphone, it rustles on the front chest.
What do you depend on?
vincmass
14 November 2014
this is my:
and this configuration page 3 module HEC
ford focus 1.6 tdci 110cv September 2009
I did not understand what to look for.
I did not understand.
but you can do it on mine?
no civil-zz
There are friends who have Ford Focus and Focus cmax 1.6tdci of 2008-2009 that the rom 508-512 with the oil change message, with the pcm as my (8M51-12A650-XE)
Why?
no,
Also the Focus, C-max and have the oil change indicator.
with the version of the ROM 508.
I do not know why my no.
maybe I have to set up something with elm?
for Spb_Focus-Man,
ok, thanks
a question for you.
I have updated the ROM to version 512 for signaling when to change the engine oil. but the alert is not the case.
I have a focus 1.6tdci- 110 hp, with fap 2009.
because it is the oil change indicator, according to you?
doing the test in the instrument panel I found this:
this is the first
[img width = 640 height = 480]
http://i59.tinypic.com/1j46xs.jpg
[/ img]
and this is the second, still remained to 0403
http://i58.tinypic.com/33kqjyx.jpg
[/ img]
because they are both updated to 512 having made the update a few weeks ago? I done something wrong?
What does NVM Target Rom? and how it gets to update it to 512?
thanks
уже сделали эту процедуру, но ничего не работает.
батарея дистанционного управления это хорошо.
Я не понимал, как он получает ...
для меня это может быть влажность?
Что я должен проверить в GEM?
где весивший дистанционного управления в GEM?
hello,
I have a ford focus 1.6 tdci 2009 with a problem.
3 days, the remote does not open and close the doors, but you can close them with a key to the driver's door.
I disconnected the battery for 24 hours, but it does not work;
I unplugged the gem, checked all the fuses, but nothing works;
tried to reprogram the remote control, but you do not hear the beep when I press the button on the remote control.
diagnosis with forscan elmconfig and gave this error:
http://i59.tinypic.com/10f9vdy.jpg
[/ img]
http://i61.tinypic.com/25zmt7o.jpg
[/ img]
my gem is this:
http://i62.tinypic.com/net6v6.jpg
[/ IMG]
What can be according to you?
Что я должен проверить в камень?
где весивший дистанционного управления в камень?
hello,
[/ img]
[/ img]
my gem is this:
[/ IMG]
hello,
[/ img]
[/ img]
my gem is this:
[/ IMG]
pogoda7:
ittrium да маленькая
большая приборка была новая.
What does the P in the dashboard?
I have another question.
is possible with elmconfig exclude the egr?
which solution taken to ensure that this valve?
my VIN is:
WF0SXXGCDS9A11308
vincmass
27 October 2013
thanks for the reply.
I apologize for the mistake, but I speak English and not Russian.
