nrgm
Foggia (IT)
FF2 Эксплуатация10 years
nrgm
20 August 2014
Is there a way to reset kam for the engine of a Ford Focus 1.6 TDCi 110PS with PCM BoschEDC16C34?
I noticed that with ELMConfig you still can not do this.
It would also be disabled with a single switch (switch off) the function of the DPF (diesel particulate filter)?
Thanks in advance for your help in the response.
nrgm
5 February 2014
For civil-zz
Hello!
I own a Focus 1.6 TDCi 110PS FAP.
It is equipped with PCM calibration number 8M51-12A650-XE (Bosch EDC16C34).
With the software ELMConfig, I tried to turn the PCM cruise control, but the function ''Integrated Speed Control'' is already active, even if in reality it is not activated. I tried to disable the function and write the PCM, but the software crashes giving an error.
It could be an error-detection software or incompatibility with the PCM EDC16C34 with calibration number 8M51-12A650-XE?
Thanks and sorry to bother you!
nrgm
11 September 2013
Civil-zz
Hello, I am a novice at the Forum!
Thank you very much the continuous development of software
I own a Ford Focus2 1.6 TDCi 109cv FAP (2009), which features a PCM Bosch brand, model EDC16C34.
With this type of ECU is not possible in any way to implement the function (in ELMConfig) reading / writing of PCM and other functions such as reset KAM, cruise control activation, deactivation FAP particulate filter, coding injectors, etc..?
Thanks in advance for any response.
