mrclio
DE (DE)
FF2 Доп.оборудование и запчасти9 years
mrclio
19 May 2016
Hello,
Sorry i dont speak russian, hope english is ok? I am from germany and need to Invert the Climatronic. I have bought now all the resistors and the Transistor. Do i understand correct that i need to cut only the white wire pin15 on c540 plug? And what about the c539 plug? Do i need to cut pin 11 or pin24? Or should I only connect the 2 wires to the plug c539 pin 11 and pin24?
Google translator does not really help ;-)
Thanks
mrclio
4 June 2013
Hello
Ahhhh ;-) I think that helps me.
I will report if i was successful. Thank you!
mrclio
4 June 2013
Hello together!
I was reading this page including all posts through google translator and yes its hard to read because i can not read russian ;( I hope i will get here an answer because i did only find your website with the information which i need.
Well, first my great respect over your work!
I have got a Focus MK2 too Year 2005 and i have got the 2 zone climate too. The Thing is that I have bought me a Facelift 2 Zone panel for this but yes you know... the Fan is in the opposite ;-)
I have looked over all pictures and your plans from the transistors and the solution from Digitale-Cj is Nice, but i have got some questions about it.
Is there a shopping list, so i know which things to buy?
In the screenshot i can see that the copper wire is passing other soldering points, is there any contact between?
And what about the other solution?
Is there a picture where i can see the circuit in the cable tree from ford? I mean a complete picture?
Maybe the question is already answered, but google did not translate everything correct, maybe you can help me?
Whould be nice if there is a picture which shows the plug from the panel and the circuit together with pictures?
Thank you in advance!
