Hy Civil-zz. I want to thank you for your effort. i bought an elm327, cheap one. After half a day word, I managed to install on Win7 64bit. It now connect to my car when using some programs included in the box. But when i try to connect using ELMConfig, latest version from Civill, I get this error:
I tried using different COMM. Same result.
When using EasyOBDII, ScanMaster, etc..it reads the car parameters, real time.
SO:1. Using ELMConfig - I still get the same error
- Run-time error '8020':Error reading comm device
I tried COMM 1,2,3,...and so on...same thing.
Win7 64Bit, driver installed, other simple softare works (only reading parameters software).
2. Using ELMFF2:- I tried Russian and English versions
- same result:
3. Using FDS:- it connects to the vehicle
- when I press "Read VIN from car" I get errorfigu
- when I pres Read Current Configuration i get the car's configuration, like in picture
- it download's ASBuilt from web, no problem there
- when I thick something, like Radio, or VoiceControl, or Reverse warning, anything, I get: "Download the HEC data from the vehicle first".
I do not have other FF2 to try.
I don't know if it is something wrong with the :
- computer (maybe comm port?? Win7 64bit. I tried like i mentioned above many comm port, same result. )
- car (few weeks ago I used IDS and it worked ok!)?
- or ELM? (Prolific drivers)
I could try to change the ELM, I haven't modified it yet. But I have to decide this days, I cannot wait too long.
Any ideea?
Thanks.
