barttigges
19 November 2014
The engineering config you are talking about, is it this part of the as-built?
<BCE_MODULE> <DATA LABEL="7D0-01-01"><CODE>1210</CODE><CODE>B588</CODE><CODE>0038</CODE></DATA> <DATA LABEL="7D0-02-01"><CODE>044E</CODE><CODE>4C00</CODE><CODE>0078</CODE></DATA> <DATA LABEL="7D0-02-02"><CODE>00DB</CODE><CODE> </CODE><CODE> </CODE></DATA> <DATA LABEL="701-01-01"><CODE>212B</CODE><CODE> </CODE><CODE> </CODE></DATA> <DATA LABEL="726-01-01"><CODE>0100</CODE><CODE>0100</CODE><CODE>0031</CODE></DATA> <DATA LABEL="726-01-02"><CODE>001E</CODE><CODE>0900</CODE><CODE>156C</CODE></DATA> <DATA LABEL="726-01-03"><CODE>014B</CODE><CODE>0001</CODE><CODE>108E</CODE></DATA> <DATA LABEL="726-01-04"><CODE>0101</CODE><CODE>0201</CODE><CODE>053C</CODE></DATA> <DATA LABEL="726-01-05"><CODE>1000</CODE><CODE>0000</CODE><CODE>0043</CODE></DATA> <DATA LABEL="726-01-06"><CODE>0000</CODE><CODE>0000</CODE><CODE>0034</CODE></DATA> <DATA LABEL="726-01-07"><CODE>0000</CODE><CODE>0000</CODE><CODE>0035</CODE></DATA> <DATA LABEL="726-01-08"><CODE>0000</CODE><CODE>0000</CODE><CODE>0036</CODE></DATA> <DATA LABEL="726-01-09"><CODE>0000</CODE><CODE>0000</CODE><CODE>0037</CODE></DATA> <DATA LABEL="726-01-10"><CODE>0000</CODE><CODE>0000</CODE><CODE>003E</CODE></DATA> <DATA LABEL="737-01-01"><CODE>0040</CODE><CODE> </CODE><CODE> </CODE></DATA> <DATA LABEL="737-02-01"><CODE>8000</CODE><CODE>0000</CODE><CODE>C1 </CODE></DATA> </BCE_MODULE> |
If so, which part exactly needs to be modified?
BTW the HVAC is now working, despite the schematics, there was no correct MS-Can on the sync module. After I rerouted the Can wires to the DLC connector it came alive
barttigges
19 November 2014
JustHunter
What about changing the other bytes? I cannot understand clearly.
Asbuilt only has byte 42 which has to been changed, right?
barttigges
18 November 2014
Sync connected to MM-Can on pin 19&20 and to MS-Can on pin 16&17 according to schematics.
Absence of MS-Can signal can cause the HVAC unit not to power up at all?
barttigges
18 November 2014
Hi,
Also installed the climate, but after powering on nothing happens.
Changed byte 42 to value 01 in the AS-BUILT
12+ volt is present on pin 14 connector 2 and ground is also in order.
Connected the CAN HIGH and CAN LOW to the CAN wires from the sync module.
But the control unit won't even turn on. When I disconnect connector 2 the blowermotor shortly turns.
Can someone offer a solution?
Is there a possibility to diagnose the HVAC unit?
barttigges
11 December 2013
Where did you get the connectors?
Откуда вы взяли, что разъемы?
quickie
Thanks for the reply
Do I need different firmware to use Chinese camera? Or is it the same?
Нужны ли мне различные прошивки использовать китайские камерой? Или это то же самое?
Tried installing a china camera today on a RP 33 set, put the camera on the fakra connector, no soldering or whatsoever.
After flashing the new as-built with the dealer, unlucky no image is to be seen.
Who can help?
Попытался установить камеру Китае сегодня на RP 33 набора, не поставил камеру на разъеме Fakra, не пайки или безотносительно.
После прошивки нового, как построен с дилером, повезло ни одного изображения не было видно.
Кто может помочь?
Which value should be changed in AS-BUILT for activation of the camera?
I still need the washer for the right side (passenger) and the watertank, then everything I need is in my possession.
Ok, I will.
I found the connector in a scrapyard. So I don't need the number anymore. I can now put it as it should be in OEM configuration.
The headlampwashers arrived today, so I only need the new washertank and the grommets to continue the build.
barttigges
12 May 2013
Найдены разъем на склад металлолома. Спасибо для смотреть друзей.
Теперь я буду продолжать делать все это оригинал или OEM качества.
Первая шайба также прибыл сегодня. Теперь нужны только нового танка и втулкой и все готово для сборки
Какого байта должна быть изменена в "AS-BUILT" данных для установки датчика скорости колеса до датчика скорости с распознаванием направления?
У меня нет ADS или около того, так, чтобы активировать его мне нужно изменить в "AS-BUILT" данные
Я хотел первоначально разъем, потому что я не люблю, чтобы разрезать на штатную электропроводку.
Также дать более оригинальный вид
I would like the original connector because I do not like to cut into the original wiring.
Also it give a more original look
barttigges
28 April 2013
Может кто-нибудь сказать мне, какая часть номер выбит на большом 6-контактный разъем жгута F221050
Мой Trend издание не имеет существующей проводки с этот разъем для разъема headlampwasher жидкости и датчик.
Спасибо!
Can some one tell me which part number is engraved on the large 6 pin connector of harness F221050
My Trend edition has no existing wiring with this connector to connecter the headlampwasher and fluid sensor to.
Thanks!
I use UCDS, but also have the option of IDS
How to activate ACS? I have already the camera and wiring, but no option found so far.
barttigges
9 February 2013
Никто не о том, как активировать датчик дождя?
barttigges
7 February 2013
Как я могу активным через датчик дождя, AS-BUILT?
Какой байт нуждается в корректировке? И какое значение?
How can I active the rain sensor thru AS-BUILT?
Which byte needs to be adjusted? And to which value?
