Hello, I want to buy a els27, as I have to do to buy one? There posivilidad shipping to Spain? thanks
Hello, I am trying to disable my particulate filter ford kuga. 2.0 tdci 136
I have seen that there are ford focus c-max and the same engine without the particle filter.
Anyone know if I can reprogram my PCM as a focus or c-max without particulate filter using IDS?
I can do this by modifying the AS-BUILT?
In kuga 2.0 140hp engines are a setup like that is called "police car" And I have a contact at Ford confirmed that these cars leave the assembly line without particulate filter, anyone know about this?
thank you very much
oscarboiro
29 September 2012
Hi, I have a 136HP kuga with keyless start.
is manufactured in September 2009.
To start it, you have to step on clutch and hold the power button.
in versions for starting 140HP clutch and you have to step to click on the power button.
I have changed the RKE module by a newer version, and now I have the boot by just one click.
You can update the firmware of the RKE module to pull up old modules with a single click?
IDS is possible to update the RKE module, but can not find any calibration file that start with a single click.
Any ideas or suggestions?
thank you very much
oscarboiro
17 September 2012
I leave here catches my HEC settings, hopefully be helpful.
As I've put a focus and a c-max 1.6 and does not work.
to make contact, the arrow turns green but does not work.
I think it has to be configured in the PCM
oscarboiro
17 September 2012
oscarboirothanks for your researches, i think it will be usefull for us..
could you provide us you PCM part number and PCM software part number? (as i understand it's your car on
video
?)[/QUOTE]
PCM my information taken from the IDS:
Strategy : 8V41C
Nombre de archivo : 8V41CB
Nъmero de pieza del mуdulo : 8V41CB
The video is of my car, but now I have another big screen speedometer.
Also with green arrow.
Comments in English I understand perfectly.
I can provide you PCM data kuga 136 and 140.
I have a 136, but my staff www.kugaexperience.com living near my home, I leave their cars to investigate.
Also I can get full ford tabs like this:
oscarboiro
17 September 2012
serge44k:
oscarboiro
Need your help, we have a question about the work the green arrow, the video for which it shows shift points are very interesting. Please take screenshots of HEC configuration to see what items were noted on the first and second page ELMconfig, also a room firmware HEC. translated by google |
Give me a few minutes to go to the car and do the screenshots you need.
ask me all the information you need.
help you in everything you need
oscarboiro
17 September 2012
DimonKur:
А у кого нибудь работает зеленая стрелка не как ограничитель оборотов, а так как у них Что за версия прошивки и почему подсветка голубая? |
green arrow comes in all kuga with manufacturing than September 2009.
Before April 2009, the arrow was red, and I think was going on from 5000rpm.
The speedometer is in blue because I've changed the leds
oscarboiro
17 September 2012
I've found my problem.
my speedometer was configured as follows:
I removed the check box and appears as average consumption and autonomy
oscarboiro
17 September 2012
Today I looked ahead.
I have not average consumption.
I have no km of autonomy.
I will restore the previous version with IDS and try again.
I put the video for you to see
[/YouTube]http://youtu.be/hYvit_Wx70A[/YouTube]
thanks for everything
oscarboiro
16 September 2012
simply does not appear.
Want to record a video?
Thanks for your answer
oscarboiro
16 September 2012
After updating the firmware.
I have no screen average consumption.
It's my fault? or is the firmware?
thanks
oscarboiro
15 September 2012
thank you very much CVIL-zz
I just upgraded the firmware on my speedometer and I can activate the eco mode.
the upgrade has taken me 17 minutes.
My driver is at 38400 silicon label, and everything perfect.
the only problem is that now I can see the screen of average consumption.
the firmware file can be replaced by a calibration file ford original, renaming the file?
If I edit the file with a hex editor to let him carry me, or give checsum failure?
thank you very much for your work
civil-zz:
oscarboiro I'm sorry but there is a mistake in your data. 8V4T-14c026-bg - it is a number of dashboard strategy software. What software do you use for getting the information? |
простите мое herror, это поймав мой новоиспеченный окно.
если вам что-нибудь понадобится, спрашивайте меня, что он принимает.
use ELM, give me a few hours, I'll connect the car and do a catch and put.
oscarboiro
29 August 2012
My Dashboard
Serial number: KHXA-11QT-S000
Part Number: 8V4T-10849-LH
hadware part number: 8V4T-14c026-bg
software part number: 8v4t-14c026-BG
calibration software part: 8V4T-14C088-BG
software version number: 03.10.2008
I had a picture on the phone with the capture, sack the night with real and you capture the command.
civil-zz:
Товарищи, не поможете мне немного? У кого есть ELM327, у кого на машинах рестайловые приборки и кто пользуется ELMConfig, сообщите, пожалуйста, некоторую информацию, если не сложно. А именно: - приборка под бензин/дизель - большой/маленький экран - градуировка шкалы спидометра в km/h / mph - и самое главное - значение поля "Номер ДЕТАЛИ" на вкладке "Информация" модуля HEC.
Можно в личку, чтобы не засорять тему. Буду очень, очень признателен. Статистика нужна для дальнейшего развития проекта ELMConfig.. |
Здравствуйте, у меня ELM327, у меня есть Ford Kuga 2.0TDCI.
Большой км / ч.
HEC мой калибровки:
8V4T-14C025-BG
8V4T-14C026-BG
8V4T-11C088-BG
Estoss нес три файла, потому что они последнее обновление я сделал с IDS перед имел следующие
8V4T-14C025-BF
8V4T-14C026-BF
8V4T-11C088-BF
В мою фотографию вы можете активировать ECO MODE.
Но на большой экран со следующей калибровки, если:
8V4T-14C025-BJ
8V4T-14C026-BJ
8V4T-11C088-BJ
IDS хранит BJ обновления BG, это обновление не доступно.
Я хочу помочь как можно больше, не владеющих русским языком, я использую Google Translate.
