Richiemac
26 December 2015
So, please tell if it is possible to add navigation to Sync 2 ?
Richiemac
22 February 2014
Ok. Done it. Perfect now. Thanks a lot
Richiemac
22 February 2014
Thank you . I will try to understand. Google Translate is sometimes difficult to follow...
Richiemac
21 February 2014
Maybe change ' OK ' button to ' M '...?
Not working ...everything else is good.
Richiemac
21 February 2014
Of course...i forgot ASL.
All ok...working now
Many thanks guys .
One thing...right side 'OK' button is doing nothing...??
Richiemac
21 February 2014
After writing to IPC and BCM...i have following DTC
BCMii B112B
RCM U0140
U0253
PSCM U0140
ABS U0140
Help !
Richiemac
21 February 2014
Parts came yesterday so i install ok.
With UCDS i write ' with cruise control ' to BCM.
Do i need to change anything else ?
Richiemac
19 February 2014
One more thing...OK button is 1687313...correct ?
Richiemac
19 February 2014
Ok, Google translate is not very accurate...
I have ordered them .
When they arrive i will report back.
Thanks for your help
Richiemac
19 February 2014
Ok, thanks.
I will order them now.
What to check on Microcat ?
Richiemac
18 February 2014
Ok guys...i am totally confused.
I have 2014 FF3 with wheel as in pictures.
I have bought wheel with BT and CC paddles.
What do i buy to make this work ?
I have UCDS to activate.
Any help will be appreciated greatly.
Авто стеклоочистителей настроен и работает нормально, сейчас ... читал и писал на BCM никаких проблем ... 2007 S MAX.
[QUOTE=krot79]Richiemac
Спасибо за вашу помощь ...
Есть ли вариант для датчика дождя, если да, то где в программе. S Max 2007 ... спасибо
Может кто поможет перевести это на английском языке, пожалуйста? ... Не осмысления .
кто может сказать мне, что выбрать для дождя / датчик света в Smax 2007 году? Спасибо ...
Работы! Благодаря гражданской ... просто нужно перевести кнопки на Английский! ... 2007 Smax модели
