vladimir-stepura
16 February 2013
Ура !! ДЕСЯТЬ, ДЕСЯТЬ, ДЕСЯТЬ - ПОЗ-ДРАВ-ЛЯ-ЕМ. Удачи. Так Держать. Успехов
vladimir-stepura
13 October 2012
Вот что пишут по ошибке Р1000
DTC P1000: OBD Systems Readiness Test Not Complete
P1000 - OBD Systems Readiness Test Not Complete
Description:
DTC P1000 indicates all of the OBD monitors have not yet been successfully tested.
Possible Causes:
The vehicle is new from the factory
12 volt battery or PCM had recently been disconnected
An OBD monitor failure occurred before completion of an OBD drive cycle
PCM DTCs have recently been cleared with a diagnostic tool
Diagnostic Aids:
The DTCs does not need to be cleared from the PCM except to pass an inspection/maintenance test.
Application - All
Key On Engine Off – DTC P1000 is ignored in the key on, engine Off (KOEO) and key on, engine running (KOER)
self-tests. Disregard DTC P1000 and continue as directed.
Key On Engine Running - DTC P1000 is ignored in the key on, engine Off (KOEO) and key on, engine running
(KOER) self-tests. Disregard DTC P1000 and continue as directed.
Continuous Memory - GO to Pinpoint Test OC .
2-й вариант
P1000 - ON-BOARD DIAGNOSTIC (OBD) SYSTEMS READINESS TEST NOT COMPLETE
Description:
The OBD monitors are carried out during the OBD drive cycle. P1000 is stored in continuous
memory if any of the OBD monitors do not carry out their full diagnostic check.
Possible Causes:
Battery or powertrain control module (PCM) had recently been disconnected
An OBD monitor concern occurred before completion of an OBD drive cycle
Power take off (PTO) circuit concern or PTO is on during testing.
Diagnostic Aids:
The P1000, inspection/maintenance (I/M) readiness function is part of the PCM strategy. A battery disconnection or clearing codes using a diagnostic tool results in the various I/M readiness bits being set to a not-ready condition. As each non-continuous OBD monitor completes a full diagnostic check, the I/M readiness bit associated with that monitor is set to a ready condition. This may take 1 or 2 drive cycles based on whether concerns are detected or not. The readiness bits for comprehensive component monitoring, misfire, and fuel system monitoring are considered complete once all the non-continuous monitors have been evaluated. Because the EVAP and secondary air injection (AIR) system monitors require certain ambient conditions to run, special logic can bypass the monitor for the purpose of clearing the EVAP/secondary AIR system I/M readiness bit, due to continued presence of these extreme conditions. P1000 does not need to be cleared from the PCM except to pass an I/M test.
vladimir-stepura
10 March 2012
Ребята! Автомат с 2.0 двигателем. Это хорошее сочетание. Радуйтесь что у Вас все хорошо. Следите за АКПП, и Вам будет ОК. Удачи на дорогах.
