Balsoje spasiba! Just to be sure here is my VIN WF0AXXWPMAES87702
Hello, would you please let me know what is the PN and where is the location of cam shaft sensor on Kuga 2.0 tdci 2014? Picture will be best one
thanky you very much
FLA
22 November 2019
Hello,
I'd like to change / setup time when the puddle light are switch ON after closing door
Current status:
1. I unlock the car - puddle light are ON
2. I open door puddle lights are ON
3. I close door puddle light switch OFF imediately -> it is possible to set up cca 5 or 10 seconds that puddle lights will be ON
Cargo Light switch ON after car unlocking.
I want to have the cargo light ON only when the trunk door is opened
Thank you!
hmmm, some more details about 10 to 11 pin please
wau that's great! Spasiba
FLA
4 January 2019
Hello
I have a Ford Kuga 2.0 Tdci 2014/04 with original rear parking sensors. Instrument cluster DV4T... with following FW:
— Graphics ROM: CV4T-14C026-DM
— MicroROM: CV4T-14C026-ZA6
— HW: C4T-14F094-BG
I want to replace my cluster DV4T... by the new cluster FV4T-10849-LF from Kuga 2.0Tdci EU 2015. My question is if the rear parking sensor will be working correctly (sound/beeb & graphic) with the new cluster. Is it only plug and play work and only to modify odometer? Or something must be reprogrammed or changed by the UCDS or Foccccus?
Hi friends,
my sister has Ford Focus Combi 2.0 TDCi Duratorq Titanium Plus (2016, at this time cca 50.000lm) what is very strange and finaly wrong is the fuel average , there is 0,7l/100km. What is wrong with the board computer?, I dont know how to proceed, may be reset or ... any idea?
thank you
Universe:
FLA Hi the chineese camera will work correctly BUT it needs to flash the LCD with one of the modified software. One of them iwas made by Quickie (presented in ADS) and the second by DarkLeo (presented in UCDS). |
Hello
what is the difference between Quickie and Darkleo software? I have rear parking sensors and I think that after LCD flash there will not see the graphic sensors on LCD screen, is it true?
hmm :-( do you know which Ford wipers has Pitch Tab and size 750/650?
Can I use 1473406 from S-Max 750 + 650mm for C-max 2012?
FLA
30 December 2016
Thanx for fast feedback, I have ELM327 USB , there is no possible to do it with Forscan or Focccus?
Hello,
I've changed my old 3,5" display by new one colour display 4.2" AM5T-18B955-CH and I have BT/USB modul on my C-Max 2011, display has a FAKRA connector , my question is if the chinese reverse camera will be working correctly. Do I have to chabge the FW or just plug and play? thank you
Is it enough just only replace old parking module by new one and the rest will be running as well? thank you
civil-zz:
понятно, что на практике такого значения Вы не увидите. просто формат ответа подразумевает, что максимально возможное значение (0xFFFF) - такое.
F1ET-10849-BJE - бензин F1ET-10849-BLK - дизель Если это не смущает, то да, можно одну поменять на другую без проблем, в остальном они совместимы. |
And what about the original Ford rear parking sensor? Will be sound running with new cluster+ new SW on C-Max 2011?
FLA
15 December 2016
Hello,
I have C-Max 2011, I have original ford rear parking sensors. I have plan to update SW or exchange cluster panel, because I want 2nd trip computer
A variant:
old cluster instrument + update SW to F1ET-14C026-AAJ, F1ET-14C026-APG/AEG, F1ET-14C318-ACB variant:
FL cluster instrument + new SW F1ET-14C026-AAJ, F1ET-14C026-APG/AEG, F1ET-14C318-AC[/B]
F1ET-14C026-AAJ
F1ET-14C026-APG/AEG
F1ET-14C318-AC
My question is if the parking sensors will be running with sound alarm or not. It does not matter if I will use variant A or B?
I have read that old cluster instrument with upgraded SW F1ET-14C026 has problem with sound of parking sensors.
thank you very much
Здравствуйте, я хотел бы изменить свой Панель приборов на моем C-Max 2011 (WF0JXXWPBJAR08365). Вы можете помочь мне, пожалуйста, чтобы проверить, могу ли я использовать Панель приборов C-Max 2015 FL F1ET-10849-BLK ? спасибо за помощь
FLA
12 December 2016
Hello, I like to change my cluster instrument on my C-Max 2011 (WF0JXXWPBJAR08365). can you help me please to verify if I can use cluster form C-Max 2015 F1ET-10849-BLK ? Spasibo
FLA
1 December 2016
Hello
Ручка КПП с подсветкой C-max 1,6 tdci 2011 WF0JXXWPBJAR08365 ? Spasiba
Ручка КПП с подсветкой C-max 1,6 tdci 2011?
