olteas01
RO
 int(3)
Ford vehicles6 years
olteas01
11 November 2018
gonghao
Hello,
You can help me with the BCM replacement procedure for a Focus 3/2011 with BCM from Focus 3.5 / 2015.
I tried replacing it with IDS and when replacing the BCM, I can not put my contact (the message appears not to see the keys) and move on to write the keys to the new BCM.
Thank you in advance!
olteas01
9 April 2018
Thank you very much, this is just the Ford dealership I know.
olteas01
9 April 2018
gonghao
Hallo,
When the BCM changed, the keys had to be rewritten?
As you rewrite them if needed, I also want to change BCM face lift 2015 (F1FT-).
All the best!
olteas01
29 September 2015
Hi guys, I am from Romania and Eberspcher problem after installing the machine.
I have a Ford Focus 3 - 1.6 TDCI / 2011 Titanium, I bought a EBERSPCHER D5WS 25 2205 which OEM parts and 100% compatible with my car (DYB), I installed on the machine and program focccus I set the Adittional Heater - ... Fuel Fired Heater Parking (FFPH) "in BCM.
I installed fuel pump and circulation pump, we put safety and F17 20 A and everything works perfectly, starts if you set from CB and his job, only when the outside temperature is below 15 degrees, exactly as written in manual.
I installed and remote control from a distance EASYSTART Remote + is marketed and Ford for this model car, I set everything in BCM to Parking Assistance - Callstart Via Radio, and works perfectly until the car enters sleep mode after 30 minutes after closing the remote control, in order then if I open the car will not start unless and starts just after it automatically unlocks the steering column, we keyless go.
I try to set in IPC and nothing changes if the program of CB for 2nd day mornings starts smoothly.
In remote installation manual from Eberspcher says as follows:
The EasyStart R+ and EasyStart Call radio remote control
needs to be activated.
To do so, connect the vehicle to the IDS diagnostic unit at an
authorised Ford partner.
Using the IDS diagnostic unit, change the CCC parameter 56
(call start of parking heater) from 0x01 no call start of parking
heater) to 0x03 (= via radio).
What is that CCC is found in IDS and something different if set with focccus?
I did a test and found FORScan the auxiliary heating module as ok, instead FCDIM module finds an error that can not be erased.
(OK) [11:20:51.559] Modul gasit: AHCM - Modulul controlului nclzitorului auxiliare
(OK) [11:20:52.885] Modul gasit: FCDIM - Comanda ventilatorului/Modulul de interfa al afiajului
(WARN) [11:20:53.403] Erori DTC in FCDIM: U2101:00-2F
Thank you in advance for your help!
