ppawel
Гданьск, Республика Польша
FF2 Эксплуатация10 years
FF2 Доп.оборудование и запчасти10 years
ppawel
5 December 2014
Hello,
I have 2.0TDCI engine with SID803 i have changed alternator type from 120A to 150A
and i would like to change it in PCM, can i do it in SID803 with newest ELMconfig?
ppawel
1 December 2014
Hello,
I have question about one thing
If i want to install this mod i need to connect HID module to the motors and to CAN, aren't there going to be any problems with HID module and AFS module when both of them are connected to the CAN?
ppawel
8 September 2014
Is it possible to reconfigure turbo/boost gauges from focus ST/RS so they will work on TDCI engine. Right now i have connected them to my 2.0 TDCI but only oil pressure is working.
Установка Keyless-системы Оборудование и запчасти Focus 2
ppawel
11 July 2014
my bad i didnt connect the cable from hatch opening button to KVM
ppawel
7 July 2014
ok i have changed to module AG now keyless entry works except rear hatch
ppawel
21 June 2014
firesanek:
you have installed the RFA module series Ax?
No i have module number 8M5T-19G481-BE
ppawel
21 June 2014
Hello i want to upgrade my keyless start with keyfree entry so i changed front door handles, locks in all doors, cables and added the antenna i rear bumper connected everything and changed configuration i elmconfig to "keyless start and entry" but it doesnt work do i need to do something more?
ppawel
12 May 2014
mlk:
Bravo!! Starting with FordPower button works as well?
Yes keys in my pocket and i only need to press cluch and FordPower and im ready to go
ppawel
11 May 2014
i have managed to get it to work.
I needed to change module 3M5T-15K602-AC to 6G9T-15K602-AB and then i was able to program the keys into the KVM
So now everything works in 100%
ppawel
30 April 2014
mlk:
as far as I remeber, you have preFL ('dorestyle) FF2 but with facelift GEM and HEC (instrument cluster), so main electronic parts are restyled
Yes but IDS still reads it as preFL so i have to program it by opening some old sesion from FL focus.
But never mind i managet to initialize all components and was able to program two keys but only "blades" i wasn't able to program wirelles keys it looks like i have wrong module (from preFL focus for normal keys) so i need to buy one made specially for keyless.
And i can start the motor only by putting key into keyhole for now.
ppawel
29 April 2014
second hand but durning initialization ids wants as built
ppawel
29 April 2014
and what about as built
ppawel
29 April 2014
Hello
I have a problem im installing keyless go from facelift focus into my pre-facelift i have connected everythig so now ineed only to program everything and here is the problem when i read my focus with IDS it doesnt want to connect with KVM i think it is because i have pre-facelift focus and it looks for old KVM.
So i have opened old session from IDS with other facelift focus and when i go to module initialization it wants AS BUILT data for KVM (731-01-01) i have given it the AS BUILT from Kuga then i wasnt able to program the keys.
And now i cannot turn the power because it doest recognize the keys.
What am i doing wrong, maybe i need AS BUILT form focus or it just wont work on pre-facelift focus.
Pls Help.
Доустановка предпускового подогревателя Оборудование и запчасти Focus 2
ppawel
3 January 2014
4ETBEPKA:
ppawel
The dashboard shows the wrong temperature, the arrow is pointing 90 degrees in the actual temperature from 45 to 110 degrees (approximately).
Maybe a faulty thermostat in the engine. Not warmed coolant goes to the radiator.
But when the dashboard "thinks" the engine has 90 degrees shouldnt it stop the fuel fired heater?
Or the heater has own termometer and works by itsef.
ppawel
3 January 2014
Is it normal that when the engine has 90 degrees the heater doesnt stop instead it goes to 50% and works until i dont stop the engine?
ppawel
26 December 2013
civil-zz:
ppawel
what the "the bluetooth module and radio are not responding" means?
the radio turns on but there is only blue screen and the buttons are not working, but sometimes when i turn off/on the radio for couple of times it starts to work and then the voice button doesnt work and i cannot connect phone to bluetooth module
civil-zz:
when does program say about invalid configuration?
when i choose "load from file" and want to load configuration from saved file before changes
civil-zz:
I need for your saved configuration to check it.
i will upload it later i have it on my other computer
civil-zz:
why did you choose "BT/VC High + BT Audio + USB + Navigation"? have you installed at your FF2 navigation and radio block from FF3?
i wanted to have voice controll of navigation on my travelpilot fx (navigation from 2008 with 4" color non touchable display) - radio is from FF2
ppawel
26 December 2013
civil-zz:
what does prevent you to do it?
Ok i have programmed the "BT/VC High + BT Audio + USB + Navigation" option now the bluetooth module and radio are not responding and i cannot load the saved oryginal settings because the program says the configuration is invalid.
Is the radio and bluetooth module behaving like that because the Travelpilot FX is not working with voice commands or the setting is not recognized by CS7T bluetooth module?
ppawel
20 December 2013
civil-zz:
Ok i will try to program "BT/VC High + BT Audio + USB + Navigation" as i presume the controll of Automatic Temperature Controll is present in this setting.
I have one more question if i can are you planing to add SID803 in PCM?
ppawel
20 December 2013
civil-zz:
your SRM config actually has the language set as Italian - 0x08. Polish - its a 0x19
So can i change this setting to Polish and will it still speak in Polish?
civil-zz:
you read. but actually your SRM has empty VIN, thats why you don't see it
Ok i will change it to VIN of my Focus.
civil-zz:
the program is designed for work with Focus2/C-Max1/Kuga1. But your SRM config has vehicle type set as Ford Galaxy, program doesn't have setting for it.
can i change this to Focus 2?
civil-zz:
looks like a previous item - your config has a setting which is unknown for the program. but actually it must present so I'll add it in next version
Right now it works with automatic climate controll but it doesnt work with my navigation blaupunkt fx and i would like to change this setting so it would work with navigation.
ppawel
19 December 2013
civil-zz:
logs?
Sorry here they are.
