ZaQik
CZ (CZ)
ZaQik
25 February 2024
try forscan 2.4.x (https://forscan.org/forum/viewtopic.php?f=13&t=23971)
manual: https://forscan.org/forum/viewtopic.php?p=70431#p70431
Ford Sync 2 - Ford SYNC® и MyFord Touch® Аудио, мультимедиа, навигация Focus 3
ZaQik
25 February 2024
низкий заряд батареи?
ZaQik
10 December 2023
Will the wiring description be the same for sync 1 as described above for sync3?
no, see to https://www.ford-focus.cz/forum/viewtopic.php?p=...1163911 point 3
Have any of you done this modification before?
yes, many times
Does anyone have a diagram for sync 1 with colour screen for ford focus mk3 FL?
http://navody.ford-focus.cz/Ford_Focus_manualy/..._de.zip
Does it need to replace the whole harness or is it enough to rework the old wires?
the reworking is enough
ZaQik
3 December 2022
only headlamps are indicated
ZaQik
12 February 2022
евро2 не хватает... нужен евро4 или евро5
ZaQik
12 February 2022
это правильная процедура в мк3.5 для 105->125 МКПП?
1. свинцовая ведет (1 катализатор -> 2 катализатора) + провода к PCM
2. замена PCM (оригинал 105 не знает 4 лямбды) - например AV61-12A650-XD
3. fw F1FA-12A650-FUC
4. модификация центральной комплектации (125 л.с.)
ZaQik
9 February 2022
SBL: BM5T-14C025-BE
F188: BM5T-14C026-BBG
F108: CM5T-14C318-AE
F120: BM5T-14C026-ACE
F121: BM5T-14C026-AFH
ZaQik
6 February 2022
yes, you can - it works
ZaQik
11 December 2021
and facelift? then you can enable CTA in both BLIS module
ZaQik
8 December 2021
CTA works only in facelift
you must CTA enable in both BLIS
ZaQik
1 December 2021
F10: https://1fichier.com/?kyfnimavvuphxhire8wo
ZaQik
23 October 2021
Keksik1980:
Точно такая же проблема, Фокус 3,походу доходит до опроса модуля IPC(знаю, что там есть эта ошибка) и вылетает в такое окно. Шнурок els327 китаец. В других прогах работает нормально. Как решить?
U2101 in IPC after IPC replacement - these are the differences in the central configuration between the BCM and the IPC; solution: read the central configuration from the BCM, write it to the IPC and then to the BCM
ZaQik
18 January 2021
avtoroman
не знаю - насосы (вода и бензин) работали, но AHCM не загорелся
ZaQik
5 December 2020
уже есть карты F9 (hm5t-19h449-fd)
ZaQik
15 October 2020
AlexSor
я имею FF3.5 бензин, AHCM добавлено - все еще не сработало, без ошибок, fw AV6N-14C080-BJ ... помог играть на AV6N-14C080-BK
ZaQik
14 June 2020
JustHunteR:
Илья_37
Да, это можно сделать, но как время будет
любое развитие в MS-CAN для ELM327?
ZaQik
6 June 2020
did you change central configuration in BCM?
ZaQik
25 April 2020
I am sorry.
I see - you have PCM typ ME17.0.2 (fw AM55-12A650-JF). This is speciality for South America. In my opinion ELMConfig does not work with it.
ZaQik
15 April 2020
Z
zappero38:
Hi,did anyone tried to use this lane keeping camera CV4T-19H406-CF with a focus mk3 ?
yes, it works
ZaQik
19 March 2020
use ELMConfig
1. configuration - read from PCM
2. configuration - check Integrated speed control
3. procedure - page 2 - read firmware from PCM to BIN-file
4. procedure - page 2 - load firmware from file (it was created in step 3)
5. procedure - page 2 - Write current firmware ... configuration will written at the end
