Vadim4egI want to visit Russia too.
In the summer time may be...
But first I have to solve the visa problems.
If I came to Russia, If you want, I'l visit you too.
volkanerr
1 March 2010
Hello again.
I failed. So I gave it up. I think there is something not compatible with my PCM.
All ford services get bored of me. I used their IDS through hours of time.
But I'm searching other modifications in this site. There are lots of good modifications.
Thank you four your help again.
edit: zero-cool; I didn't understand your private message. Can you ask it again in a simple language? Or say it Vadim4eg, then let him ask me
Also I understood the humor above about KGB
And that was good.
volkanerr
22 February 2010
We programmed GEM and IC modules as in the instructions. But still CC didn't activated. Still IDS gives Data Error when entering programmable data>personal settings menu.
Then we reprogrammed PCM as 3m51-FJ code. But now car gives steering default. My car has no ehpas. But it gives ehpas fault.
Afternoon we will try to reprogram PCM.
Nothing worked + a new fault.
I'm very upset.
volkanerr
22 February 2010
How can I learn my PCM number? 1.6 duratec 100hp engine.
Morning I'll go to the service and I'll use the IDS. On the IDS, from which menu I can learn the PCM code? Or can you say my PCM code from my VIN number? My VIN number is; WF0MXXGCDM3J46755
volkanerr
20 February 2010
Vadim4egI used google.translate but on google.translate I cannot be logged on. When I logged on, it goes back to russian version. To post messages I have to log on.
But no problem. I learned the buttons
Reply and Send buttons are on the left
volkanerr
20 February 2010
Buttons worked.
I used the method rear window heating button pressing to test the CC buttons. And all of buttons beeped and signals lighted on. So I understood that I used the correct pins and the correct resistances.
Thank you for this test method. Even technician didn't know this method to test the buttons. He said me to test the system with buying a new steering wheel with CC.
Now the last step is the installation of the as-built data. Services work with appointment. So installation will be on monday.
I'll be here friends.
Note: To use forum in russian is very difficult. I translate your messages but I cannot translate the buttons
I always press the one on the left
volkanerr
20 February 2010
I want to learn russian to read your forums
What a perfect forum...
Thanks for all of your help.
volkanerr
20 February 2010
Thank you FORDIAGNOSTIC_1.
Now it's clear how to as-built. I saved the images.
But still I didn't understand the logic. Is this data installs a new level program to my GEM? Is this different from the one in it now? Is this new data for GEM contains CC in it?
Edit: Vadim4eg explained it.
Thanks vadim4eg.
volkanerr
20 February 2010
Thank you Vadim4eg.
What a cool thing to be helped from Russia when technicians can'T help me
Vadim4eg;
When this as-built data installed to my old -CF ending low level GEM, is CC be activated directly? Or it activates the menu that enables CC?
Last;
How can you find these data
From ETIS?
volkanerr
20 February 2010
Today I'm going to plug my original, not as-builted GEM. This GEM does not allows to enter the CC settings menu. Says DATA ERROR. And it's code is 14A073-CF This GEM which ends with CF is low level one said technicians. Still can it be activated for CC?
zero-cool has already sent me as-built data for my VIN as;
720-01-01 C4C2 1115 D5
720-02-01 5757 5757 57DD
720-03-01 5746 304D 589D
720-03-02 5847 4344 4D9F
720-03-03 334A 3436 374B
720-03-04 3535 98
726-01-01 6404 50FE E5
726-02-01 2704 338Е
Is this data suitable for my VIN? And if I as-built this data, is CC will be activated directly? Or menu will be activated to enable CC? Is this data generated for my car only with additional CC?
Sorry, but all of you know more than my technician. So I try to understand you. But it'S a bit difficult.
I have to learn a lot from you.
Thank you.
volkanerr
20 February 2010
Also the resistance values are ;
unpressed; 2110
on; 1110
resume; 600
+; 300
-; 120
off; 0
I used 120,180,300,510,1000 ohm resistances.
volkanerr
20 February 2010
As-built data that I sent you was the data that zero-cool sent them to me. My new GEM is programmed with the data of a 2010 trend c-max with cruise control.
But I will as-built the data that zero-cool sent to me, to my original GEM module soon. Before it, with the plugged new GEM module, I will check the buttons with rear window heater test.
I saved the as-built data of my VIN. And I will use it.
I wish it works.
Thank you.
volkanerr
20 February 2010
Thank you so much Vadim4eg.
I didn't know a way like this to test the buttons. This will help me a lot.
Is this method still works for cc buttons if CC is not activated succesfully?
volkanerr
20 February 2010
Sorry but something is misunderstood I think.
Our friend said something about rear window heater button. But I didn't understood. And then I translated the last message and think that my word "resistance" (which I meant resistance in the buttons) was understood as rear window resistance.
If I misunderstood, then can you give some more details about the relation of the CC buttons and the rear window heater button and also signals to test?
Thank you.
volkanerr
19 February 2010
Thanks four your help. And sorry for not being able to speak Russian.
My GEM module code is 14A073-CF. I tried at ford service center. They have to different IDS's. Also we tried with old WDS. We activated CC from PCM. But IC and GEM is in another menu. But when we try to enter "personal settings" menu in "programmable parameters" IDS gives "DATA ERROR". We openned session in another ghia, then saved session on my trend. But after opening a new session, again IDS gives the same DATA ERROR.
Then I found a new version of GEM module which has a part number of 14A073-FB from a wrecked 2008 FII. Technicians said this new GEM module is the high version, my original GEM module is low version which does not contains CC menu in it. So we tried the new module.
Today, during all day I plugged the new GEM module which ends with FB. We download GEM module program of a 2010 c-max trend which has CC originally. We entered its VIN number as mine. By this way, we programmed new GEM module to my trend.
All features like "leaving home" which doesn't exist in my old GEM worked with the new one. Also we activated CC from PCM, IC, and GEM. But still CC does not take into action.
I checked my resistances, buttons a lot of times. But they work pretty good.
I use the #10 and #18 pins in the socket. I measured the voltage between these pins and its about 4.5V.
I know that there is no connection between GEM and the steering wheel. But I plugged my buttons directly to the socket on the GEM module.
Am I doing wrong at any point?
Thank you for your help.
volkanerr
19 February 2010
Hello.
I'm from Turkey. I found your forum. And learned a lot about my ford. Thank you.
Now I'm trying to install cruise control to my c-max. I plugged in my buttons directly to the fuse box. But with IDS I cannot enter the "personal settings" menu in the programmable parameters list. In the PCM I activated CC. But in the fuse box and in the insrument cluster I could not activate cruise control.
My fuse box is 14A073-CF. Is this module support cruise control? Physically it is the same with other 14A073 modules. But the last letters CF is different. I tried to copy the program of the module of a ghia to my trend with IDS. First it saved. But after closing the session and opening a new session again it didn't enter to personal settings menu in the programmable parameters menu.
How did you solve this problem with 14A073-CF module?
Also I tried to download the module program from ford etis directly with VIN number. But in Turkey, there is no trend with originally cruise control. If some of you have an originally cruise control in his gasoline trend, please give me your cars VIN number. So I download it's module program from etis.
I use google.translate to read your forum. So sorry for the language.
Thanks for your help.
Здравствуйте.
Я из Турции. Я нашел ваш форум. И узнали много нового о моей Ford. Спасибо.
Теперь я пытаюсь установить круиз-контроль с моей C-Max. Я подключен в мои кнопки непосредственно на предохранитель. Но с IDS я не могу войти в "личные настройки" в меню программируемый список параметров. В PCM я активировал CC. Но в блок предохранителей и в кластере Приборостроение я не могу активировать круиз-контроль.
[B] Мой предохранитель окно 14A073-CF [/ B]. Этот модуль управления круиз-поддержка? Физически это то же самое с другой 14A073 модули. Но последнее письмо CF отличается. Я попытался скопировать программу модуля Ghia моей тенденцию с IDS. Сначала он сохранен. Но после закрытия сессии и открытия новой сессии вновь не приходило в личном меню настроек в меню программируемых параметров.
Как вы решите эту проблему с 14A073-CF модуль?
Кроме того, я пытался скачать программный модуль от Форда ЕТИС непосредственно с VIN номер. Но в Турции, нет никакой тенденции с первоначально круиз-контроль. Если некоторые из вас изначально круиз-контроль в его бензином тенденции, пожалуйста, дайте мне ваш номер VIN автомобиля. Так что я скачать это программный модуль с ЕТИС.
Я использую google.translate читать Ваш форум. Простите за язык.
Спасибо за вашу помощь.
