wy852852
CN
wy852852
7 May 2014
ittrium:
На всякий случай отпишусь тут. У wy852852 была проблема с китайской кодировкой в системе. ElmConfig криво работал, т.к. китайская традиционная кодировка использует для каждого символа больше одного байта. И похоже в программе конвертация строк в бинарные данные происходит некорректно. Как я уже говори адаптер тут совсем не при чем
Thanks ittrium very much!
wy852852
4 May 2014
sergkurz:
Вы обсуждаете китайский автомобиль. VIN LVSHCFAE89F361500. А у него все одинаково с европейскими собратьями?
T think same,becuse it is C307
wy852852
26 May 2014
civil-zz:
wy852852
also - do you use the original frw.dat file from archive?
Hi
1:I did not use its own archive fil
es, using the ELMconfig's the archive(frw.dat)
ps:HEC and PCM programming error will appear engine failure, but can be cleared
Thank you very much
Best regards!
wy852852
3 May 2014
civil-zz:
wy852852
do you have logs of flash attempt?
Hi Civil-zz
I flash HEC ROM 0508 by AUTO and 256 size, attempt:
wy852852
1 May 2014
civil-zz:
wy852852
Hi civill-zz
Sorry I Forget log
I try again today
Thanks
wy852852
30 April 2014
Hi ittrium
I want programming HEC ROM 0509,but have error
Please tell me how to set
Thanks
http://pan.baidu.com/share/link?shareid=3048008...3096873
http://pan.baidu.com/share/link?shareid=3054800...3096873
Диагностический адаптер ELS27 Запчасти и Услуги
wy852852
6 January 2014
ittrium
Thank you
wy852852
6 January 2014
Serj63
Hi!
I wasn't what you say
I am not what businesses
Not to clone
I am a loyal FORD FOCUS fans
In this forum has been for 2 years
Learned a lot of knowledge
I despise clone others products Chinese businesses
I looked down to do the fake China businesses
I wholeheartedly want to order a ELS27
If you can order 5 better, my friends want to do FOCUS
Thank you
wy852852
5 January 2014
Hi Ittrium
I want to buy ELS27, I'm from China Beijing.
Can I pay it with PayPal
Please tell me the account number, price and freight
My email:wy852852@163.com
Best regard
Thank you
wy852852
2 December 2013
Hi civil-zz
Add functionality to ELMconfig, with a key to unlock the vehicle headlights illuminated simultaneously, such as Buick
Can do it?
Thank you
wy852852
8 September 2013
civil-zz:
Hello
my 2009 ford focus has U2202 DTC, how clear?
I see you in here to write a U2202 DTC
Программы для диагностики и конфигурирования на базе ELM327 # entry12737908
Do you know?
Please tell me how to do.
Help me
thank you
wy852852
7 September 2013
DarkLeo
Hello
Tell me how to do.
thank you
wy852852
20 July 2013
civil-zz:
ffclubshnik
И за какой же вирус нынче принимают ELMConfig?
wy852852
Yes I saw, that's why I'm asking you about the block size, in log it's doesn't match the right one.
hello civil-zz
Re-test, respectively, with different byte, see screenshots
What is the problem then? How can I correct programming HEC 0509ROM?
THANKS!
wy852852
18 July 2013
civil-zz:
ffclubshnik
wy852852
Thanks reply, how do I do to program success 0509rom
wy852852
18 July 2013
civil-zz:
wy852852
please share the logs made during your attempt
hello civill-zz
Sorry, I made ​​a mistake pictures now posted a complete
wy852852
20 July 2013
civil-zz:
wy852852
Strange.. Program lives the life of its own.. What size of block is written in the bottom field when error appears? (on your screen it's invisible, located behind the error window)
hello zz
You see I posted the AT LOGS do?
wy852852
20 July 2013
civil-zz:
wy852852
hi civil-zz logs as follows:
wy852852
16 July 2013
hi civil-zz
ELMconfig 0.2.9,drivers using FTDI connection is 5,000,000,
all modules can be properly read the information, but it is not programmed HEC 0509rom
block size with auto or 256 or 128 have also experienced the same mistake
What is the cause of this error? May I ask how to solve
Please help, thank you
wy852852
21 January 2013
[QUOTE=civil-zz]Обновил ELMConfig. Версия 0.2.4 > civil.iffc.ru
hi civil-zz
this link to download is not 0.2.4, is 1.2.1b
wy852852
29 December 2012
civil-zz:
wy852852
no, cause not in your system or adapter. due to uknown reasons the program sends improper data to a vehicle..
hi civil-zz
I know where the problem is, and should is ELM37 problems is China ELM327 1.5 errors, I can buy your ELM327 USB?If you can, please tell me how to buy, thank you
