Панель приборов РП-32
РП-7 до 01.11.2012 года и теперь только РП-33
СТ
приборная панель, приборка, комплектация, дисплей панели приборов, индикатор на панеле, панель приборов
Azrail13
18 August 2011
1,5M
6,3K
O_zone
16 August 2017
cavallo76
maybe you just don't give to your fueltank get drained? )))
if I'm not mistaken, on restyles it should appear if fuel left 60km to empty. and did you try to put his IPcluster instead of yours?
arunparthan
16 August 2017
Hi,
I am from Dubai, Ford Focus 2013 S. Small screen IPC with trip reset button, no other options.
I want to update my IPC firmware to have trip computer and cruise control. I don't want to replace the IPC.
Please suggest me the files and update order. ELM327 500K is ok for this update?
My current IPC
PRP
17 August 2017
Hello, I had the same IPC as yours. If you make a software update, you will have a trip computer, but if you do not have buttons on your steering wheel, you will not be able to change the readings. You will only see the remaining miles until the fuel is running out.
First, change the steering wheel and then you can update the software.
cavallo76
20 August 2017
O_zone
My friend is 1200 km from me (friend by online).
He has cmax and different parts (mine is F1ET10849BLE, I don't remember him part number).
Can it has updated software?
cavallo76
20 August 2017
Part number of my friend's cluster is F1ET10849BJK
arunparthan
27 August 2017
I am planning to upgrade my IPC with the New US IPC. So I have some doubts. please help me.
The US IPC I am having:
WH: BM5T-14C226-BE
SW: BM5T-14C026-BBB
PROM: BM5T-14C026-AKC
P/N: CM5T-10849-CTG
You suggested me on the forum:
BM5T-14C025-BD - sbl (secondary bootloader)
BM5T-14C026-BBD - main
BM5T-14C026-ACC - graphic
BM5T-14C026-AFE - calibration
Do I need to upload all the files including the SBL?
Can I upload only the calibration / eeprom file?
or calibration and main file except graphic file. because i am not concerned about the latest screen graphics. I just want to convert US IPC to Euro standards.
MRteam_Factis
27 August 2017mobile
Подскажите , пожалуйста , у меня ст приборка американка , стоит рестайловая прошивка, машина дорестайл естественно . Так вот бсм ругается на не Соответствие конфигурации, это можно как то вылечить или откатываться надо на дорест?
PRP
28 August 2017
arunparthan
You should only upload these three files in the same sequence.
The BM5T-14C025-BD - sbl (secondary bootloader) file is integrated into "FoCCCus" and used to make a connection with the dashboard.
arunparthan
28 August 2017
PRP
Thank you very much for the information.
Actually I uploaded BM5T-14C025-BD and then BM5T-14C026-ACC-graphic then BM5T-14C026-BBD-main then BM5T-14C026-AFE-calibration.
Nothing went wrong it is working. Is there any problem in the future? or do i need to erase SBL or do i need to re upload as you mentioned?
PRP
28 August 2017
Once everything is working, there is no problem in the future.
arunparthan
28 August 2017mobile
Thank you
temkasp
14 September 2017
Renatush:
WOV
Спасибо, проверил сегодня утром у себя Вариант: заливка прошивки замены значка - eeprom не st - eeprom st, убирает ошибку u3000 (вариант для авто с esp). В варианте без esp достаточно залит: прошивку замены значка - eeprom не st
Мне такая комбинация действий не помогает( Ошибка висит. Авто с esp. Какой конкретно файл eeprom st нужно заливать? Дорестайл последняя прошивка приборки. И нужно ли в конфиге BCM включать, точно не помно, 236 параметр вроде на ST?
Renatush
14 September 2017
temkasp
Возможно вы что то не так делаете.
Вот ссылка на нужный файл для смены значка Панель приборов (сообщение #17691328), скачиваете его и устанавливаете как это в сообщении и написано. А далее все как и описывалось выше: после установки файла заливаем через focccus eeprom не st - далее eeprom st, убирает ошибку u3000 с помощью forscan. Все операции я делал на приборке рп7 с рестайлинговой st прошивкой. Ничего в ВСМ не менял, так как изначально заливал st eeprom при прошивке приборки.
temkasp
15 September 2017
Renatush:
temkasp
Вопрос именно про файл eeprom st. Прошивка у меня РП-7 дорестайл BM5T-14C026-ACC, BM5T-14C026-BBD, BM5T-14C026-AFE (ибо штатный парктроник). Залил файл смены значка ручника (значёк сменился), потом файл eeprom мой приборки (это вроде BM5T-14C026-BBD, сейчас точно не скажу), потом залил eeprom st F1ET-14C026-BSD. Ошибка U3000 остаётся. Просто перечитав ветку запутался совсем, нужно убрать ошибку U3000, пункт СДС можно активировать и без st файла, каков порядок действий. Меня смущает прошивка дорестайл и eeprom st рестайл (или нужен eeprom st не рестайл.). Авто с esp.
WOV
15 September 2017
temkasp
Конечно нужно заливать дорестайл.
temkasp
15 September 2017
WOV:
temkasp
А идент файла подсажите плиз.
Renatush
15 September 2017
temkasp
Рекомендую так же обратит внимание на этот момент Панель приборов (сообщение #16233978)
DE10: FDFFDF9F - горит восклицательный знак, Brake не горит
DE10: FDFFFF9F - не горит восклицательный знак, Brake не горит
DE10: FFFFFF9F - горит восклицательный знак, Brake не горит (значение с завода)
Сам ставил значение с завода
temkasp
16 September 2017
Renatush
Установлено значение с завода.
Renatush
16 September 2017
temkasp
Тогда как писали выше Панель приборов (сообщение #18499267)
karlon3
16 September 2017
temkasp
Для дорестайла файл для функционала st не нужен. Нужно в as-buid поправить 1 пункт. И в приборке поправить и все.
temkasp
16 September 2017
Понятно. Спасибо всем. Буду пробовать.
temkasp
21 September 2017
Вообщем, пичаль( Ни какие манипуляции не помогли - ошибка так висит(
BOSSSNIK
24 September 2017
привет всем. ребята скажите пожалуйста у меня фокус 3 2.0 повер шифт пакет рп7 я хочу прошить щиток приборов под рестайлинг с помошью ELS27 и FoCCCus . какие файлы мне надо скачать ??? какая последняя версия прошивки ??? заранее благодарен вам всем .
karlon3
24 September 2017
B
BOSSSNIK:
В шапке же ссыль? Панель приборов (сообщение #18096319)
BOSSSNIK
24 September 2017mobile
Ой спасибо ) друг скажи ещё одно у меня машина заводится с ключа есть разница между прошивками ??
karlon3
24 September 2017
B
BOSSSNIK:
Разницы ни какой. Хоть без нее езди. Она тока выводит инфу.
BOSSSNIK
Скажите пожалуйста мне нужно залить все 5 файлов ???posted image
MRteam_Factis
25 September 2017mobile
Подскажите , на рп7 с рестайловой прошивкой чтобы активировать ст конфиг, надо только файлик соотвествующий залить в приборку или в бсм менять конфигурацию ?
zyrgiv
Всем привет, прошил американскую рп 7 рестайловой прошивкой, перестала гореть подсветка кнопок на магнитоле (магнитола redpower a150 2din)есть ли связь,может в настройках приборки полазить? Еще отключал сигнал о непристегнутом ремне(не через ELM)
Sums
25 September 2017
Доброго времени суток. Прошу помощи с приборкой. Заменил приборку на куге с монохрома на РП7.
HW CV4T-14F094BG
SW FV4T-14C026BF
P\N DJ5T-10849-TF
DE02 менял 6 и 7 байт на 1. Цифровой спидометр не появляется.
не могу активировать цифровой спидометр.
Нештатный БК
Часы в авто
Ложные сообщение БК (глюки)
